06 LT Heater
Old 02-01-2010, 10:07 AM
it is the trans cooler lines. ive had the water pump to the trans lines leaking. get both fixed Asap! another problem im starting to hear about is the manifold gaskets for our cars going bad
Old 11-10-2010, 08:32 PM
So, coolant is topped off........... no coolant leaks. Still no heat when using remote start. What can it be? Heater controls? None of the reply's above really addressed the issue of no heat if the coolant isn't low. On my 06 LTZ no heat when using the remote start and the coolant is fine. Even the temp gauge says the car is fully warmed up, but it still blows cold.
Old 11-14-2010, 09:49 AM
it is the thermostat same thing happend to mine when i first got my monte i have the same gen as you replace the thermostat. when it gets stuck open it will warm up normally when driving it wil give off heat do to pressure from the engine. when at idel it will push out cold air. if it does it again after you replace the thermostat i would do a thero flush on the system do to a air pocket
2003 SS
09-24-2017 08:38 AM
Lee55
10-05-2007 08:20 PM
jogasz28
01-15-2007 11:42 PM
Cheesey
11-12-2006 03:57 AM
Stag
11-13-2005 04:57 PM
Quick Reply: 06 LT Heater
