06 Headlight Lo not working help!
Hello all! I'm new here looking for some help... I got up for work wednesday morning and went out to start my car and noticed that my passenger side headlight was out... everything else on the headlight works (marker, hi beam) I tried replacing the bulb... did not work, tried replacing the fuse even though it did not appear to be blown that also didn't work. Everytime I hit the lock or unlock on my key fob (whatever one would cause the lights to come on) I would hear a clicking noise from that side. I have not tried replacing the relay but from reading on google if you hear the clicking your relay is likely not the problem.
the driver side works just fine it's just passenger side lo beam.. I'm going to try a new relay just because it's the last thing I can think of.. please help! Thanks!
Repair Guide: How to adjust headlight beam
MonteLSV6
FWD Tech Guides '95-'07
17
Aug 24, 2022 06:55 PM
6th Gen ('00-'05): 2005 Monte Carlo headlight issue
Anthony Scott Fowler
May 9, 2019 05:06 PM
