7th Gen ('06-'07): '06 Charging issue
Old May 27, 2018 | 07:27 PM
phuntley's Avatar
Originally Posted by 96z34man
Get the narrowest crowbar you can find. Take off the passenger side wheel and the liner behind it. Then put the crowbar on top of the tensioner and push down.
This is a lot of effort, but $10 is a whole lot cheaper than $75.
Exactly what I ended up doing. The factory lug wrench actually worked perfectly, it's short and strong. I did have to have a friend jimmy it over the last pulley (I routed belt everywhere else and left water pump pulley for last.)
I really could not see ANY way that damn tool could get that tensioner down as far as I had to pry the damn thing!
I also found a handy photo of the serpentine drive system, they are all over the internet.
My issues turned out to be a combo of bad ground lead to the battery, bad alternator, and it took out my battery. And I just replaced the belt while I was doing the alternator. I did luck out on the battery, Autozone replaced under warranty because I found my receipt with the old cell phone number it was under. Phew.
Baby purrs like a kitten again!
