6th Gen ('00-'05): 04, no low beams, not fuse/relay/bulb/switch... HELP
Old Sep 24, 2020 | 02:46 PM
Matthew John Zeigler's Avatar
Exclamation 04, no low beams, not fuse/relay/bulb/switch... HELP
Good Day!
My wife bought a 2004 monte 3.4. The marker/parking, running and highs all work, no lows. I replaced the switch since that's what seemed to be the most popular answer. No fix. I checked all the fuses, all good, no fix. I checked the relay on the back side of the driver side fuse block, swapped it with a known good, still not working. I checked the bulbs and they are all still intact and I removed and cleaned the headlight ground. Still no low beams. What am I missing? What's next?
Old Sep 24, 2020 | 11:02 PM
Anyone? I've read so much on this, checked so many things I'm at a loss here.
Old Sep 25, 2020 | 03:21 PM
Originally Posted by Matthew John Zeigler
What's next?
Once you've checked the obvious stuff, its time to break out a multimeter and wiring diagram and start checking.
Test each accessible location (say from the bulb socket moving up stream) until you find out where the break is.
Old Jan 4, 2021 | 08:34 PM
USPatriot1963's Avatar
It is the multifunction switch. I have replaced dozens of these. I had to drive to work for a week holding the lever back in the "high beam" position.
bcsfd306
Jan 12, 2019 07:58 PM
Zod642
41
Jan 27, 2018 09:56 PM
westcoastmc
Mar 27, 2017 05:51 PM
svzpt71
May 11, 2015 06:30 PM
kolakoff
Jan 17, 2011 06:20 AM
