04 monte ss issues with hard acceleration
Old Feb 19, 2014 | 02:11 PM
Ardell's Avatar
I replaced with NGK iridiums because I heard about bosch issues with these engines. And Wide open throttle makes sense lol. I'm gonna get the fuel pressure regulator tested shortly, just cleaned my K&N and can say it was severely plugged. Looks like when they cleaned the car for my purchase they sprayed something that coated it as well. It's all clean now so hoping that helps some
Old Feb 19, 2014 | 05:33 PM
Ardell's Avatar
So cleaned my k&n and sensors etc and issue still persists. Going to try and get fuel pressure regulator tested tomorrow and possibly look at a new coil pack. Any other suggestions or is that my best route to take right now?
Old Feb 19, 2014 | 07:44 PM
What code are you throwing?
Old Feb 19, 2014 | 07:56 PM
Ardell's Avatar
I had it scanned but I lost the damn paper I wrote it on. Was a misfire on cylinder 6 I believe
Old Feb 20, 2014 | 06:26 AM
If it is specific to a cylinder, I would swap the injector with another injector.
The FPR and other fueling issues are more common to throw a p0300 which is random misfire.
If this is cylinder specific swap some stuff around and see if the code follows.
Old Feb 20, 2014 | 05:31 PM
Ardell's Avatar
Ok had the codes read today and was a p0300b misfire along with multiple misfire detection. Would I be right then in assuming it's likely to be my coil pack is failing under load?
Old Feb 20, 2014 | 05:43 PM
dbaldwin's Avatar
Nope like chibi said, thats more likely a bigger fueling issue.
Old Feb 20, 2014 | 05:45 PM
Ardell's Avatar
Hmm wonderful lol so what do I test now? The fpr?
Old Feb 20, 2014 | 05:47 PM
Ardell's Avatar
I also had a p1133b code pop up on the first scan as well, could a bad 02 cause issues like this?
Old Feb 20, 2014 | 05:49 PM
dbaldwin's Avatar
First place to start. Thats beyond my experience though.
blades3001
May 16, 2020 12:32 PM
jcquick
Oct 25, 2012 09:20 AM
gkathleenw
Feb 29, 2012 11:03 AM
radiantdragoon87
Aug 16, 2011 10:10 PM
MPS81
Apr 15, 2007 08:58 PM
