6th Gen ('00-'05): 03' Monte Carlo is multi cylinder misfire and now won't start
My 03' ss threw the fault code for random/multiple cylinder misfire on my way home one day. We came across one of the coil packs wasn't throwing spark so we got a new one. A couple of days had passed by the time I got the new one and before I went to replace it I went to check the battery level and ended up starting the car out of habit and it attempted to start then died right away. (Up till this point I had started it several times and it would run like crap but it would always start). replaced the coil pack and it wouldn't start and the new coil pack wasn't throwing spark so we replaced the whole thing ( the ignition control module and all three packs) and it still won't start. Any ideas what would be keeping it from starting?
Since you went for the gusto and changed all the coils and ICM, have you verified if you are getting spark at this point? If so, how did you validate spark?
By pulling the end of each of the spark plugs wires off the coil packs one at a time and attempting to start it. The coil pack ends throw plenty of spark and I doubt that it's the plugs because i replaced all of them about 2 months ago.
Thanks for the suggestions I'll check those options. It was also suggested that the Camshaft sensor could have went out because of something that we did when we were initially testing it. How difficult is that to replace?
I can't speak for camshaft, because I haven't touched that. If you're getting spark, I would test fuel pressure. There's a release valve on the rail, and you can test pressure there. I would make sure you're getting the right amount there before you go messing with hard stuff, because it's really easy to test.
6th Gen ('00-'05): Cylinder 2 misfire detected
George Joseph Wickens
Nov 21, 2018 03:54 AM
RhetoricCamel
Feb 1, 2013 07:50 PM
