Cylinder 2 and 5 not firing
Old Nov 29, 2015 | 07:03 AM
Kevinslover04's Avatar
Default Cylinder 2 and 5 not firing
Hello I have a 03 monte carlo ss cylinder 2 and 5 aren't firing at all I switched coil packs around I replaced the coil packs spark plug wires fuel filter spark plugs also the control module and the computer and still nothing cylinder 2 and 5 have nothing I believe it's a electrical problem what should I do thanks
Old Nov 29, 2015 | 08:06 AM
Budsjlm's Avatar
Which control modual and computer?
Old Nov 29, 2015 | 08:24 AM
I put back in my old computer and the module is for the coil packs
I honestly dont know what's causing it
Old Nov 29, 2015 | 08:39 AM
Budsjlm's Avatar
Did you have the old ignition control modual tested? Did you replace the coil befor or after the modual?
