02 power window switch
the up side of switch(driver side) seems to be getting less and less of a contact, needs replacing, does the door panel need to come off? I notice screw under grip, looks like it may hold top plate down. hand in cast,looking for easy way out ,,help
Have fun with that
I had to replace mine as well in my 2001. The top panel (the panel where the switch is located) can pop off. But you have to be VERY careful, otherwise you'll ruin the finish of the top panel.
I'd get a panel-popper to do it.
