~ Performace Injected Tuning for Monte Carlo ~
Old Aug 29, 2007 | 01:49 PM
Default ~ Performace Injected Tuning for Monte Carlo ~
[align=center]
Has any member used Pit-Tuning ?[/align][align=center]Performace Injected Tuning[/align][align=center]Please post `if you have.[/align][align=center][/align][align=center]
Chevrolet
Monte Carlo
1997-2005
3.4L and 3.8L
$495.00
Chevrolet
Monte Carlo SS
1997-2005
LS4
$495.00 [/align][align=center][/align][align=center][/align]What We Do[align=center]Interfacing with the vehicle’s computer, Performance Injected Tuning Inc. will improve the spark timing curve, and air/fuel ratios to create a more efficient burn of the fuel in the cylinders. This results in an increase in fuel economy, while at the same time producing more horsepower and torque. While these are the basic services offered, PIT Tuning is capable of enhancing the performance of the vehicle regardless of any aftermarket modifications made by the owner.
Home | Contact Us[/align][align=center][/align][align=center]
About Us
Why Choose PIT?
What We Do
Tunable Vehicles
Testimonials
FAQ's[/align][align=center][/align][align=center][:-]Click Link[/align][align=center][/align][align=center]http://pittuning.com/tunable.html[/align][/align][/align]
Old Aug 29, 2007 | 01:55 PM
Default RE: ~ Pit-Tuning for Monte Carlo ~
Performace Injected Tuning Inc. is a company specializing in enhancing the information in a vehicle’s computer, or PCM (Powertrain Control Module). In doing this PIT can achieve many desirable traits from a vehicle that can be custom tailored to the uses of the vehicle which the manufacturer does not offer.
This state of the art software is used by more than 50 franchises throughout North America, some of which are new car dealerships offering greater operating efficiencies for new vehicle customers.
The United States Defense Department used this software to improve performance on more than 50 military vehicles during Desert Storm in 1991. This contract with the U.S. Defense Department is ongoing to this day, as they continue to utilize this software.\
Increased Mileage[/align]Increased Mileage[align=center][/align][align=center]PIT Tuning achieves very impressive fuel savings by making changes to the PCM (the vehicles computer). Using specific air/fuel ratios and spark timing maps which have been carefully measured and tested on a dynamometer, your vehicle will be optimized for fuel efficiency. This has been shown to increase fuel economy by up to 5-6 miles per gallon on gasoline engines, and up to 11 miles per gallon on diesel applications.[/align][align=center]PIT Tuning programs throughout the entire throttle range, offering maximum fuel savings for everyday driving. Hand held programmers generally only offer gains when the vehicle is at wide open throttle, or when the driver has the pedal to the metal.[/align][align=center]
Increased Horsepower
Through the use of a dynamometer, PIT Tuning’s program modifications make large increases to the power of the vehicle’s engine. Gasoline engines have shown gains of between 15-30% more horsepower and torque.
Diesel engines can be reprogrammed to produce 50% or more horsepower and torque with supporting aftermarket upgrades. PIT Tuning guarantees higher power gains than any hand held programmer on the market.
PIT Tuning can program for increased power on anything from stock vehicles, all the way to supercharged or nitrous oxide equipped vehicles.
Premium fuel is never a requirement, but if you specify to us that you will use it, then even more horsepower can be gained.
Increased Response
PIT Tuning always programs to maximize response. This means the engine does what you want, faster than it used to. Transmission shifts on automatic transmissions can be improved so that they are firmer, decreasing time between shifts.
Increased Response
[/align][/align][/align][/align][/align]
Old Aug 29, 2007 | 08:00 PM
04 Intimidator's Avatar
That doesn't seem to be a software you can order. I couldn't find an order sheet for it and looks more like a $500 drive in service. Did I miss something on the site?
BeachBumMike
Oct 19, 2013 05:55 AM
JC Colon
Sep 4, 2013 10:19 PM
BrettSollosy47
Jul 12, 2011 09:28 PM
purewhitemonte
Jul 21, 2008 01:20 AM
skidoo6713
Nov 11, 2007 06:23 PM
