fuel filter replacement
Old Mar 10, 2013 | 10:26 PM
bobkl's Avatar
Default fuel filter replacement
im trying to replace the fuel filter and the nuts is kinks rusty and messed up a little and i'm wondering what size wrench it use's......is it a 17mm??
Old Mar 11, 2013 | 12:35 AM
Can't you take your new filter and test fit a wrench to it? The other end has plastic clips on it. Hope this helped. Others will chime in when they sign on in the AM.
Old Mar 11, 2013 | 07:44 AM
turbo monte's Avatar
I would try what zippy recommended as well. Turbo Monte has all braided fuel lines so its completely different. When I pulled out the factory lines I didn't take much care with them and kinda just yanked them out lol
Hopefully someone will chime in with the correct size for you.
Old Mar 11, 2013 | 03:29 PM
bobkl's Avatar
I could take line off but still need to hold the nut on other end that's on the line. I know what size the nut on filter is but don't help holding the one on the fuel line on the car
Old Mar 11, 2013 | 05:18 PM
Are you able to get a crescent wrench on it? Or a set of Visegrips? Hopefully you can get an answer, I'm like TurboMonte, all braided lines totally different set up now... Sorry
Old Mar 11, 2013 | 08:38 PM
bobkl's Avatar
why you need all steel braided lines?
Old Mar 13, 2013 | 08:39 PM
bobkl's Avatar
where would be the best place to get the fuel filter bracket? used would be fine with me. i looked on ebay and nothing so far
Old Jun 14, 2013 | 01:01 PM
MJClemm's Avatar
Can not believe they didn't make the fuel filter and lines out of Stainless steel, the most important MAINTENANCE part under the car, it it always rusts out !... I'd have been more then happy to pay extra for stainless !... Pain in the ***......
Slamjunk
Sep 29, 2014 03:56 PM
MJClemm
Mar 18, 2013 07:10 PM
bobkl
Mar 12, 2013 04:42 PM
RickCoMatic
Dec 20, 2007 01:45 PM
01BlkSS
Jan 12, 2007 12:03 AM
