MCF Website Problems & Issues This area is for problems or suggestions relating specifically to the MCF site, not the car.
turn signal problem
Old Aug 17, 2021 | 07:19 AM
dustysix's Avatar
Default turn signal problem
When i bought this car the hazards were erratic, the switch was intermittent, I knew from my Corvette that if the hazard switch went bad I wouldnt have signals, So i replaced it. After i replaced it the turn signal worked way too fast. Im aware that the hazard switch is the turn signal flasher. and im sure thats the problem. Unfortunately i threw the old one away!! I bought the switch online and they replaced it but it still does the same thing because they sent the same switch. I have replaced all,4,turn signal bulbs with the bulbs listed in the owners manual. I feel that i need a different flasher
Old Aug 19, 2021 | 10:21 AM
If you have access to a salvage yard you might want to check an see if you can find one there, Check Rock Auto for this part they may have a better one too.
SteveQ
Oct 3, 2019 01:44 PM
donny57
Dec 1, 2017 04:46 PM
Dj_bosse
Jul 8, 2016 05:58 AM
michelob
Aug 31, 2014 04:47 PM
RickCoMatic
Jan 20, 2013 08:57 AM
