3rd Gen ('78-'80): Wiring Harness Install- HELP!!
Old Mar 2, 2013 | 11:49 AM
jmak33's Avatar
Default Wiring Harness Install- HELP!!
I'm trying to remove the wiring harness in my 78 Monte but I'm not sure the right steps or all of the steps I need to take to get the old harness out and put the new harness in. The new harness is a painless wiring 18 circuit GM keyed harness and seems pretty straight-forward on the directions. The biggest problem I have is around the firewall, getting to all the wiring and exactly what parts I need to remove before I can pull out the old harness without damaging the connectors that I will need for the new harness. I think I might have bitten off more than I can chew but it's too late to turn back now. Any and all comments/tips would be greatly appreciated!!!
Old Mar 2, 2013 | 11:56 AM
I highly recommend marking each and every connector...use a peice of masking tape on each connection. And number it... Use a separate peice of paper to document each connection.and its corresponding number...
Most of all... Take ur time!
Old Mar 2, 2013 | 01:26 PM
The wire harness is probably close to one of the first parts of the car in the assembly process so i think to remove it properly you would have to have most of the interior stripped out.
red04montels
Sep 21, 2009 04:13 PM
txboyd12
Dec 1, 2007 07:35 PM
dirty
Oct 14, 2007 05:04 PM
zipsayain
Jul 28, 2007 01:27 PM
OdinPaladin
Jun 21, 2006 02:15 PM
