Where do I get styrene plastic to change gauge lights?
Old Jan 31, 2013 | 08:13 PM
milrlyt's Avatar
Default Where do I get styrene plastic to change gauge lights?
Apparently they're available at a local craft store but I've had no luck at any of them. Michael's, JoAnns, nothing. I can't find transparent colored ones online. Anyone know where I'm supposed to get it?
Old Jan 31, 2013 | 09:06 PM
Personally, I think you would be best converting the lighting to colored LEDs. It probably takes more work to do, but in the end, the color will shine true.
My experience is paint or other materials to cover the bulb and allow a different color shine through eventually wear down (as the bulbs do give off heat and cause the color to degrade).
Old Jan 31, 2013 | 09:11 PM
milrlyt's Avatar
Yeah, but it's quite a lot of work to solder in resistors and the LEDs. I've heard styrene works really well from folks here. Especially since I have the instrument panel with 6 gauges... it would take a long time lol
Old Jan 31, 2013 | 09:44 PM
Found this on Ebay LINK:Transparent Blue Plastic 3 Sheets for Gauges Free s H | eBay
This item is available in other colors, it is ebay item number 370384897451
Old Jan 31, 2013 | 10:45 PM
Overdose666's Avatar
Old Jan 31, 2013 | 11:02 PM
milrlyt's Avatar
Yall are great. Thanks guys.
Old Feb 19, 2013 | 06:42 PM
So i just installed those USSpeedo leds in my cluster, the instructions were for the wrong vehicle but i guess and got it working. The color is beautiful but kind of dim, but it's probably because my ABS, TRAC OFF, and CEL are on and incandescent, seems to be drowning them out. The ZZP voltage booster seems to be helping a bit though.
Old Feb 20, 2013 | 08:25 AM
06BlackJaySS's Avatar
I Got some from michael's but it was the plastic used for stencils. My cluster looks pretty good! It has a nice blue look to it.
Old Feb 20, 2013 | 06:25 PM
shotime105's Avatar
Did these have to be soldered in?
Old Feb 20, 2013 | 10:13 PM
Yessir, I've never soldered anything before in my life, but i managed to get em in without too much trouble. Only problems i ran into was having to switch the LEDs around since the polarity of the board isnt marked, and the light for the temp gauge had some of the glue around it and was a bit difficult to solder.
For the price its most likely a waste of money. It's just 9 cheap LEDs and vague instructions for a different vehicle. I'm trying to find soem good brighter LEDs to replace em with right now.
ctownbandit
18
Oct 13, 2018 04:49 PM
THAV
Sep 3, 2014 07:50 PM
milrlyt
Jan 29, 2013 12:11 PM
dcnaser
Mar 25, 2012 07:40 PM
drmrgal
Apr 8, 2011 05:11 AM
