turn signal
Old Feb 24, 2007 | 01:10 AM
turner_dtp's Avatar
Default turn signal
hey im having problems with my turn signal. when im driving ill turn it on and then it just stops blinking and turns off? what do u think it is? a fuse? any thing would help... oh and i jsut got my radiator flushed and my message center is saying that i have low coolant levels..im pissed now because i dont know if i might have a leak in my system or if the blockheads at jiffylube half-a$$ed the job..ne help
-thanks
Old Feb 24, 2007 | 03:52 AM
benhillzone3's Avatar
Default RE: turn signal
take it back to jiffy lube show them that they low coolant warning is coming on and that they need to address it since they did the flush on it,
Old Feb 24, 2007 | 12:38 PM
bbengineer's Avatar
The turn signal issue is likely the hazard button/signal flasher on it's way out...
Try turning the hazards on and off a few times... that should get your signals working again (for a while at least)
The low coolant issue is likely a gummed up coolant level sensor. Probably needs to be cleaned or replaced..
BBEngineer
Old Feb 24, 2007 | 12:55 PM
wutever you do dont take it back to that jiffy lube lol
trey0503
Apr 27, 2018 11:39 AM
kent00SS
Jul 16, 2007 03:56 PM
djizzle
Jan 19, 2007 01:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
