Help with new Speedometer for my Intimidator SS
Old Feb 21, 2007 | 10:42 PM
RocknSS04's Avatar
Default Help with new Speedometer for my Intimidator SS
I just bought this '02 Intimidator guage cluster of ebay for the #3+ RCR+ red bowtie + dale's sig' on the face of the speedometer. How much is involved in swapping out the speedometer, or face, or what ever it takes to put this speedometer into my car? I can't swap clusters because of my boost guage.
Can anybody help me with this please?
This is the unit:
http://www.cardomain.com/ride/2319272
[IMG]local://upfiles/1500/7249608CCF014489BEF330566BC653E6.jpg[/IMG]
Old Feb 22, 2007 | 10:18 AM
wiz kidd's Avatar
Default RE: Help with new Speedometer for my Intimidator SS
yours didn't have a specialty cluster in it?? if its an intimadator edition it should have
Old Feb 22, 2007 | 03:15 PM
bbengineer's Avatar
ORIGINAL: RocknSS04
This is the unit:
You need to remove the lens, then remove the speedometer needle. You can then pull off the speedometer overlay (with the clear backing attached)...
Swap in the new one, recalibrate and install the speedo needle and reattach the lens...
You can see some more details on working on the cluster
http://bbengineer.home.comcast.net/c...usterlight.htm
Email me if you want more help
BBEngineer
Old Feb 22, 2007 | 09:59 PM
RocknSS04's Avatar
My cluster is a specialty item. So is this new one. I intend to blend the 2 together to make a unique, but yet all factory, gauge cluster. One of a kind.
Old Feb 22, 2007 | 11:23 PM
benhillzone3's Avatar
any luck so far on installing the gauge face?
Old Feb 23, 2007 | 06:55 AM
RocknSS04's Avatar
Haven't got the new one yet, should be here next week. Just paid for it. Probably going to be a couple of weeks before it's done. Working 60hrs a week right now, plus the 2hrs a day commute.
Calibrate the speedometer? Is it hard?
Does anyone see any real problems?
Old Feb 23, 2007 | 02:08 PM
well good luck and we will be looking forward to seeing the results
Old Feb 23, 2007 | 10:07 PM
RocknSS04's Avatar
So are these one-piece overlays as in bbengineer's link?
If so, do I cut and splice rare overlays, or do I move the boost gauge to the cluster under the radio, an S.W. 1 1/2" unit and keep them intact?
Old Feb 24, 2007 | 12:36 AM
bbengineer's Avatar
ORIGINAL: RocknSS04
No, the LS cluster is one piece, the SS cluster is 3 pieces... no cutting needed...
Here's what the SS overlays look like:
Just remove the lens and you'll see...
BBEngineer
Old Feb 24, 2007 | 03:58 AM
bb how much is it to install cause this is a little too much for me to try right now. i have an 04 ls model
