Trim Removal
Hey I have some trim I wanted to paint up to match the exterior (Red), anyone got any tips or directions on how to remove these? On the stereo and heat/ac controls, i am interested in removing the outer "ring" part...
The outer ring of the stereo just snaps out. I use a butter knife to get it started and just follow it around unsnapping as I go. Good luck!
The dash part is a bit more difficult and I have never tried to remove the window switch trim.
for the dash you will have to remove the whole thing like in my video here:
http://www.youtube.com/watch?v=muBMP6BSkKc
the ones on the door you will probably have to remove the whole door panel
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
in all honest i dont know though, but i can give you this advise, if you've ever dealt with any trim you can easily deal with any new car, their almost always intuitive and rather simple connections, in GM they tend to be snap in parts. i believe the ring trim for the radio in the 7th gen is just a snap-in piece.
this thread does give me an autoimmunity to ask though as i do have a piece of trim even i am afraid to play with with out any knolage, so if anybody has any knowage or experience removing the vinyl covered dash its self, the very top piece, that spans the the entire dash, i would greatly appriciate any help
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
carefully ![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
i havn't yet had the time to google this up yet, but i'll get around to it, in the mean time any advice would be great ^_^
really? i'll have to look at it, i'm sure the bottom part of the dash has to come out to get at the screws. does that black peice against the glass just pop out? i kind of played it with the other day for a moment seems like it might just pop out?
Trim ring has three snap in peices on each side (none on the top or bottom) When I took mine out I broke it. Fixed it now but it was broke.
The Dash comes out again with snap in clips, The only thing that you will have to undo is the Switch panel on the right side of the cluster. This panel is again snaps out but be carfull since the top dash pad is soft and can mark easy.
The window switches will have to come out with the whole door panel. There is no way of getting them out otherwise. Be carefull there as well since GM decided to make the wire leading the the switches short and you dont have much room to play with.
I would suggest on going to a local auto supply store and getting panel remoel kits (basicly hard plastic knifes that are different shapes and angles.
Oh I forgot they can pop off from the door once the whole soor skin is removed the door. There is three spring clips that hold that on. The top side of the handle and the switches and silver sections all come off as one peice. You can remove the switches but the palstic holding them in is thin.
