Sub Question
Old Feb 20, 2013 | 11:11 AM
It's probably one of 3 things..
Bad ground
Amp can't handle that output that the sub is asking for
Sub can't take the power from the amp
Old Feb 20, 2013 | 01:34 PM
Who knows, i ripped some wires apart this morning when loading my trunk. Reconnected them all and it doesn't seem to have made a difference. When it gets warmer out i'll have to look into it more.
Old Feb 26, 2013 | 12:10 PM
SSilver's Avatar
Have your headlights been dimming when the bass hits? If so, it could simply be that the battery is not able to supply the current required for loud bass...
If not that, I would look closely at the amp not being up to the task.
Old Feb 26, 2013 | 03:28 PM
Nope, no dimming issues. Haven't noticed any problems since i reconnected some wiring i ripped apart a while back.
Old Feb 28, 2013 | 10:06 AM
milrlyt's Avatar
If you do start noticing problems again, in all likelihood it's probably something like your amp can't handle it or poor wiring. Have you checked how hot the amp gets after the problem happens? Where have you set the crossovers on the amp and what kind of amp is it? Tried swapping phase?
You may just want to check and re-check your wiring yet again. If it was poor before, there might be other hazards elsewhere along the installation. Hope you don't have anymore problems.
77gp
29
Jan 25, 2013 04:15 PM
Boxman420
23
Apr 28, 2011 12:54 PM
novagenesis300
37
Jan 19, 2011 04:51 AM
jdawgkemp
May 9, 2009 12:10 PM
skidz84
Aug 5, 2007 11:52 AM
