Sub Question
Old Jan 24, 2013 | 04:02 PM
Warhorse's Avatar
Mines a sealed box as well, mostly listen to Dubstep, but like rock and deathmetal as well, this handles all very well. The Kenwood I have, has a bass remote that's handy to adjust as needed. Body messages are awesome!!
Here's mine-Name:  2012-04-08171239_zps1294cbad.jpg
Old Jan 24, 2013 | 07:23 PM
Looks very similar to mine (fitting between the wells)...Minus the capacitor...
As im sure you read... I too have a seperate sub control ****...!
My box is just a weeee bit LARGER than yours...
Are those 10's?
Old Jan 24, 2013 | 08:54 PM
Like some of the others have stated, a sealed box will be considerably smaller.
Here's mine. I'm running one 12" Alpine Type-R, in a custom sealed box I built, paired with an Alpine mono amplifier mounted to the back of the box. The amp is hidden, on purpose, but easily accessible by folding the back seat down. The box is mounted to the cross member under the rear deck with two L brackets and overhangs the spare tire well by about four inches. I can still remove the spare cover and tire without moving the box. I designed the box and setup this way and it works well.
Old Jan 25, 2013 | 11:10 AM
Nice clean build/ Insthal Matt!
I think from now on...When I wanna tinker ... I think Id like to come to your place! Clean work bench...Nice arranged assortment of tools all hanging up
nice and neat.... Im definately Impressed...
I take it that you were insahling your complete system with haveing the complete rear seating area removed?...
Old Jan 25, 2013 | 11:46 AM
Thanks. Yes, removing the back seat gave a bit more working space but I took it out mainly to run the wiring.
Old Jan 25, 2013 | 12:29 PM
This is the exact same custom box and setup, as above, when I had it in the 03. I repainted the box black when I installed it in my 06. The box's internal volume is within Alpine's recommended volume for the 12" Type-R in a sealed box. The first picture gives the best size relation of the box to the trunk.
Old Jan 25, 2013 | 12:41 PM
Nice job, I am jealous.. I will have to get something going on mine here soon.
Old Jan 25, 2013 | 02:39 PM
Warhorse's Avatar
Are those 10's?
Hey STUMPMI, Dig it, love the way you can designate the amount of bounce!! Those are 12" subs, kinda hard to tell from the pics! Amp is a Kenwood KAC 8151D, 1000 watt, does the trick, bet yours REALLY sounds killer, mine is jumpin' and you have 3000 more!! Head unit is stock with the 6 speaker and 200 watt amp. Rock on!!
Old Jan 25, 2013 | 04:07 PM
Thanks!
Im shocked after 14 yrs it still sounds like it did when it was new...
Old Jan 25, 2013 | 04:15 PM
Warhorse's Avatar
Thanks!
That's kick-***!! Especially if you bump like I do, a real testament to the duration factors!!
Nice ride as well, dude!!
Leprechaun93
24
Feb 28, 2013 10:06 AM
Boxman420
23
Apr 28, 2011 12:54 PM
novagenesis300
37
Jan 19, 2011 04:51 AM
jdawgkemp
May 9, 2009 12:10 PM
skidz84
Aug 5, 2007 11:52 AM
