sub with factory deck?
Old Mar 20, 2011 | 10:33 PM
eric.parent's Avatar
Default sub with factory deck?
I bought my sub a week ago and can't quite afford a new deck so i bought this stinger converter. I do not know which wires to put into this stinger converter and all the instrucktions say are "this side power source" "this side amp" I know what clip to take the wires out of but does anyone have a schematic of the wiring harness in the deck and know which wires to put into this line out converter? Really wanting to have my sub pounding but I can't figure this one out. Any help would be greatly appreciated.
Old Mar 20, 2011 | 10:40 PM
psot a pic of the converter? ive done it before but i can't remember what it looks like without looking at it
Old Mar 20, 2011 | 10:59 PM
This is what it looks like
Stinger SGN12
Old Mar 22, 2011 | 04:42 AM
02montecSS's Avatar
Are you planning on installing an eq or any other kind of sound processors in the car?because if not, you can skip all the bs and hassle of pulling out the front deck and just tap into the monte's rear deck 6x9s.run the RCAs down to amp, run the blue remote wire to the back from the fuse box and there you go.don't forget about your main ground and power wire though!lol.if you are planning on adding sound processors, it's best to pull out the deck.just google a wiring diagram for your monte.it's what I did, I have the stock deck with a kenwood eq, audiocontrol epicenter, and 2amps
bcnewfie
25
Oct 5, 2014 03:00 PM
perryp
Jan 10, 2012 10:16 PM
tpulliam79
Oct 25, 2011 01:40 PM
CashMoney
May 17, 2011 03:45 PM
jkeller783
May 1, 2008 11:06 PM
