Audio/Video Build: Sub/Amp upgade
Old Nov 3, 2014 | 07:29 PM
Scott 05's Avatar
Default Sub/Amp upgade
looking into buying one
<b><u>Alpine SWR-12D4 Type-R 12" Subwoofer with Dual 4-ohm Voice Coils</u></b> Alpine SWR-12D4 Type-R 12" Subwoofer with Dual 4-ohm Voice Coils
and matching it with
<b><u>Rockford Fosgate R500X1D Prime 1-Channel Class D Amplifier</u></b> Rockford Fosgate R500X1D Prime 1-Channel Class D Amplifier
I currently have 2 10" subs and my amp is wired to my battery with an 8 gauge wire... apparently it's a no name but is clearly labelled as 8 gauge on the wire, my brother suggests I strip it near the battery and measure the diameter to double check, my question is will an 8 gauge wire be suitable for this setup or should I be looking into a
<b><u>4 gauge like this one </u></b> 4 gauge like this one
and lastly, is the sub and amp a good match?
thanks in advanced for any input
Old Nov 3, 2014 | 09:24 PM
You should upgrade the wire but if you are going to you might as well go with 1/0 gauge wire. It will better in the long run no matter what. Its not very hard to run it through the car. I have it in my monte. The alpine type r is a great subwoofer for sure but you could get a bigger amp if you wanted with something rated around 1000 watts rms at 2 ohms. That amp would still work with no problems as long as you set the gains on it correct.
Old Nov 3, 2014 | 10:06 PM
Scott 05's Avatar
thanks for the suggestions : ) will be placing the order soon, now time to research some plans for a nice sub box
I'm thinking ported but if it proves too difficult to build to match specs I may just do sealed, my current 10's are in sealed and I liked it when they were new... now they are really old and sound crappy
any good sites for free box plans?
Old Nov 4, 2014 | 12:15 AM
I am pretty sure I saw you on facebook before. Look up the page low budget car audio and someone on there would be able to help you with that. I have never done a box before.
Old Nov 4, 2014 | 12:51 AM
Scott 05's Avatar
thanks! yea im on facebook and I just joined and posted in that group : )
Old Nov 5, 2014 | 05:13 PM
SSilver's Avatar
You really don't need that large 0 gauge power wire for your setup. 4 gauge is more appropriate for the setup you are planning.
Old Nov 5, 2014 | 05:46 PM
you are right that 4 gauge would work but why not just do 1/0 since you are already rewiring cause when it comes to people with bass it normally seems they want to keep upgrading.
Project Monte 04
Mar 15, 2011 07:40 PM
One Dark SS
Nov 11, 2009 11:34 AM
jaws2008
Apr 27, 2009 12:09 AM
