RPM gauge is way off
Old Feb 4, 2014 | 05:29 PM
sdowney's Avatar
Default RPM gauge is way off
Hi all,
So I have no idea why, but my RPM gauge is way off. When I idle, the RPM gauge is below zero, and when I accelerate, the needle goes up at a normal rate but its just off. It doesn't go to where it normally would. The belt is spinning when the car runs and the car runs fine. I don't notice the car act weird or run funny. It runs good and everything works like normal.
Anyone know what would cause this?
Thanks!
Old Feb 4, 2014 | 05:56 PM
I'm pretty sure that would be the cluster itself. It can be rebuilt
Old Feb 4, 2014 | 06:14 PM
Like Brent (JuniorCar) said it can be rebuilt, it's most likely the stepper motor which is a very common problem for the 6th gen Monte....
Old Feb 4, 2014 | 06:55 PM
x3, stepper motors are a common problem.
Old Feb 4, 2014 | 08:17 PM
sdowney's Avatar
Default Thanks for such a quick response!
Thanks all!
What exactly is a stepper motor? The little motor in the gauge cluster that moves the needle on the gauge?
Old Feb 4, 2014 | 08:33 PM
Yep, each needle has its own stepper motor. We have a how-to guide, actually recently talked about them too. But Im on mobile right now and can't link it easily
Old Feb 5, 2014 | 05:47 AM
ssdriver's Avatar
Default tach problems
My speedo was acting up and I read somewhere that if you remove the neg. battery cable and then replace it the stepper moter will return to normal operation. I tried it and it worked, no more erratic movement.
It's worth a try, cheap fix.
Good luck
By the way, the RPM gauge is commonly called a tachometer. Just my 2 cts.
Old Feb 6, 2014 | 01:41 PM
sdowney's Avatar
Thanks all. I ordered the part and it's on it's way
Habbibie
Feb 18, 2015 05:51 PM
RickCoMatic
Feb 4, 2011 09:44 AM
monte carlo 3831
Jul 9, 2009 09:03 PM
BeachBumMike
May 5, 2007 10:05 AM
Visual7
Aug 29, 2006 08:50 PM
