RPM gauge is way off
Hi all,
So I have no idea why, but my RPM gauge is way off. When I idle, the RPM gauge is below zero, and when I accelerate, the needle goes up at a normal rate but its just off. It doesn't go to where it normally would. The belt is spinning when the car runs and the car runs fine. I don't notice the car act weird or run funny. It runs good and everything works like normal.
Anyone know what would cause this?
Thanks!
Thanks!
My speedo was acting up and I read somewhere that if you remove the neg. battery cable and then replace it the stepper moter will return to normal operation. I tried it and it worked, no more erratic movement.
It's worth a try, cheap fix.
Good luck
By the way, the RPM gauge is commonly called a tachometer. Just my 2 cts.
Good luck
Habbibie
Feb 18, 2015 05:51 PM
RickCoMatic
Feb 4, 2011 09:44 AM
