replacing speakers
Old Jul 13, 2009 | 09:52 AM
White04monte's Avatar
Default replacing speakers
to keep things brief my window has been squeaking and i figured out that it is the felt strip on the inside and ordered one for each door from chevy. so i figured since i will have my door panels off i will replace my speakers since they get a little staticy sometimes. but to get to my question with most speakers having a higher resistance then factoy do you think i would have to replace the amp(really don't want to) or is there some good speakers that will sound at least as good as the factory.
well i tryed to keep it short lol
Old Jul 13, 2009 | 12:46 PM
Chevycarlo97's Avatar
You don't necessarily need to replace your stock amplifier. You can simply look for speakers with the right impedance (probably 2 ohms) and look for the right size that fits your car. I made a couple clicks around and found that sonic electronix has some choices that will probably fit. You can look elsewhere for more brands and better prices but this is to show you.
http://www.sonicelectronix.com/viewc..._id=35&f_31=97
Now they will more than likely sound better than stock but which speaker is better than the other is opinionated. Just look at the reviews and determine which one best suits you. Remember to find ones relatively close to your amplifiers output in RMS.
Old Jul 13, 2009 | 01:16 PM
very helpful thanks for the input
Old Jul 13, 2009 | 02:14 PM
04MonteLS's Avatar
Get 2ohm speakers if you can, that way you'll get the max output from your amp. I replaced mine w/4ohm speakers and while it sounds better than stock, doesn't get quite as loud due to the increased resistance and reduced output from the amp as a result.
I also highly suggest putting some sound dampening material on the door, it'll keep out more of the resonant noise as well as make your speakers sound much better. And you won't have turn the volume up as loud either because instead of the door absorbing the energy from the sound waves hitting it, the dampening will redirect those waves back into the cabin resulting in louder, more crisp sound.
I just installed some SecondSkin Damplifier Pro this weekend and all I can say is WOW!!!
Old Jul 13, 2009 | 06:33 PM
01-ON-AIR's Avatar
sound deadening is awesome, and stock sucks if you can afford it replace it.
i would recommend cascade spray deadening, and dynamat extreme.
if you have to replace your stock stuff, do your research.
Old Jul 13, 2009 | 08:36 PM
04MonteLS's Avatar
IMO, SecondSkin > *
Lorenzo
19
Nov 15, 2012 08:28 PM
s_dot03
May 26, 2010 09:27 AM
Eyedea
Jun 23, 2005 04:48 AM
bk4256
Mar 28, 2005 06:37 PM
sporges
Mar 25, 2005 12:29 AM
