rear defroster
Old Jan 12, 2012 | 07:35 PM
boggie's Avatar
Default rear defroster
I am going to give this one more try and then of to the dreaded dealer.
Here goes everytime you turn on the rear defroster the radio get static and you can't listen to it unless you shut of the defroster how come
Old Jan 12, 2012 | 08:57 PM
Maybe there is a short where the defroster plug wires go and it's shorting on the body. I would inspect the wires around the rear windows for cracks or breaks in the insulation. Just a thought.
Old Jan 12, 2012 | 11:39 PM
KJRich's Avatar
That could be, when you consider the rear defroster doubles as the the radio antenna.
Old Jan 13, 2012 | 07:24 AM
03SSLE's Avatar
It's possible that you have a bad/loose contact somewhere in the circuit. Check the connectors that slide onto the tab at the rear window. Make sure they are clean and tight. It could also be dirty or worn switch contacts. Installing a 0.1 uF ceramic capacitor on the lead that goes to the defroster will help eliminate any ripple that may be present. The + side of the cap goes to the switch and the - side goes to ground.
Old Jan 13, 2012 | 10:13 PM
boggie's Avatar
Thank you to all of you that helped will check in the morning once again thank you
Old Jan 13, 2012 | 11:11 PM
there is a module behind one of the rear quarter interior panels. it handles the defroster and antenna. My guess, it's bad. There are two different part numbers for it and I think roughly $20 a piece from the dealer. I was looking into that when my defroster stopped working and now I think it's a failed circuit breaker.
If you are comfortable taking the interior trim apart, I'd say get the module out, head to the dealer with it and swap it. I want to say it's on the passenger side.
Hope that helps.
MJClemm
Oct 9, 2022 09:13 AM
rjmfa
Dec 22, 2012 12:17 AM
SSDriver8
Jun 13, 2010 08:25 PM
davesbedroom
Jan 7, 2007 11:45 AM
01pacecar
Apr 29, 2006 12:38 PM
