rear deck
Old May 6, 2008 | 03:20 PM
aussiek2000's Avatar
Default rear deck
How do I get to the speakers in the rear deck?
Old May 6, 2008 | 04:37 PM
scc24540's Avatar
Default RE: rear deck
what car do u have? lol
Old May 6, 2008 | 06:24 PM
1998 monte carlo LS
Old May 6, 2008 | 06:31 PM
scc24540's Avatar
pull the back seats down, those 2 bolts you see loosen them or take them out. then push up on the carpet on the rear deck or grab it anyway you can and remove it. its best if you pull it straight towards you after you get the backside of it above the headrest. also dont forget to remove the seatbelts from inside it. then after its removed. theres a piece of insulation, remove that and there are your speakers.
to reinstall just reverse what i said but make sure the carpet is in the track properly
Old May 7, 2008 | 05:14 AM
ok, thanks.
Old May 13, 2008 | 09:36 AM
sws2000's Avatar
Does this also apply to a 95 Monte Carlo with 60/40 fold down seats? I got as far as taking out the bottom seat cushion and removing the bottom bolts for the seat backs but I still can't get the upper backrest to come off to gain access to the rear deck and I don't see any bolts to loosen.
Old May 13, 2008 | 02:40 PM
sws2000's Avatar
Nevermind, I found this:
http://www.w-body.com/forum/index.php?topic=52388.0
So it seems all I have to do now is bend the 2 metal tabs from the trunk.
montedubedition
Jul 25, 2009 10:30 PM
onlyonetaz
Aug 7, 2008 03:33 PM
Bxbootlegger
Feb 14, 2008 08:34 PM
86Ls
Jan 1, 2008 05:23 PM
06LT3
Jun 20, 2007 07:16 AM
