rear deck
How do I get to the speakers in the rear deck?
RE: rear deck
what car do u have? lol
RE: rear deck
1998 monte carlo LS
RE: rear deck
pull the back seats down, those 2 bolts you see loosen them or take them out. then push up on the carpet on the rear deck or grab it anyway you can and remove it. its best if you pull it straight towards you after you get the backside of it above the headrest. also dont forget to remove the seatbelts from inside it. then after its removed. theres a piece of insulation, remove that and there are your speakers.
to reinstall just reverse what i said but make sure the carpet is in the track properly |
RE: rear deck
ok, thanks.
RE: rear deck
Does this also apply to a 95 Monte Carlo with 60/40 fold down seats? I got as far as taking out the bottom seat cushion and removing the bottom bolts for the seat backs but I still can't get the upper backrest to come off to gain access to the rear deck and I don't see any bolts to loosen.
RE: rear deck
Nevermind, I found this:
http://www.w-body.com/forum/index.php?topic=52388.0 So it seems all I have to do now is bend the 2 metal tabs from the trunk. |
