Rado install/no power
Old Nov 26, 2010 | 11:06 AM
dirtwing's Avatar
Default Rado install/no power
I'm attempting to install an aftermarket HU, dash apart, aftermarket HU hooked and had power to it. Unhooked to tidy up wires, reinstalled HU.....no power! I hooked up the stock HU....no power. What did I do and more importantly how do I fix it.
Old Nov 26, 2010 | 11:20 AM
Enzo354's Avatar
STILL SLOW
Check all your fuses.
Old Nov 26, 2010 | 11:28 AM
dirtwing's Avatar
Have any idea which fuse box the radio fuse is located?
Old Nov 26, 2010 | 12:07 PM
dirtwing's Avatar
Checked all the fuses in drivers side fuse box and all appeared to be good. Fuse boxes under hood appears to be mostly engine related. Unsure were to look next.
Old Nov 26, 2010 | 12:18 PM
Enzo354's Avatar
STILL SLOW
Check the passenger side too, I kept blowing one there when I tried to hook in a new amp.
Old Nov 26, 2010 | 01:51 PM
dirtwing's Avatar
Found it on the passenger side, Thank You very much!
Old Nov 27, 2010 | 12:06 PM
Milhouse's Avatar
Yep, anytime the aftermarket deck won't work, then stock deck either, it's a fuse. Glad you got it worked out.
Shandley
FWD Tech Guides '95-'07
Oct 21, 2019 09:02 PM
sfritz85
Sep 27, 2011 06:47 PM
SickParadox
Mar 1, 2011 10:14 PM
2003supersport
14
Jul 11, 2010 12:32 AM
jibb3r
Aug 3, 2009 05:22 PM
