new stereo install power wire
Old Sep 26, 2011 | 04:11 PM
sfritz85's Avatar
Default new stereo install power wire
I have just started my search for a hole in my firewall to pass a power wire thru for some new stereo eqpt. Has anybody had any luck with using a pre existing hole or have you had to drill a new pass thru?... i am trying to do this install with out drilling...
Thanks for feedback...
Old Sep 26, 2011 | 04:18 PM
I ran mine threw the fender & cut a slit in the rubber boot that the door wires go threw & ran it inside the car
Old Sep 26, 2011 | 04:56 PM
sfritz85's Avatar
Wow... Thats a wicked idea!.. thanks for the help!
What size power wire did you run?... how much are you powering?
Old Sep 26, 2011 | 05:38 PM
I'd try to go through the boot in the firewall.
You can drill in it, just make sure you're not hitting anything on the other side, I wouldn't go through the fender personally just because I didn't like seeing the wire there everytime I opened the door, but it's up to you.
I've gone under the grommet and it fit fine for me.
How To Run Sub Wires in 00-05 Monte Carlo-red04montels - YouTube
Old Sep 26, 2011 | 08:11 PM
walkingonabullet's Avatar
wow bad ideas abound, never compromise seals. theirs a perfectly good, perfectly and nealry unused rubber gasket in the passenger and driver side firewall foot panel area.
Old Sep 27, 2011 | 01:46 PM
sfritz85's Avatar
Thanks everybody for your input...
was the unused gasket in the foot areas pretty easy to get to? and what size wire did you use there? that looks pretty substantial...
Old Sep 27, 2011 | 06:47 PM
Boxman420's Avatar
its not hard to get to just pulll the carpet back a little and move the seat all the way back. so its not in your way. that wire looks like 0 gauge. i ran 0 through mine no problem.
Murray137
Oct 20, 2012 08:13 PM
Brad
Jun 18, 2012 09:22 PM
SickParadox
Mar 1, 2011 10:14 PM
superrod29
Feb 25, 2011 09:50 AM
StaleAle
May 11, 2008 11:31 PM
