Radio upgrade
Old Sep 27, 2007 | 07:23 AM
BankheadSS's Avatar
Default Radio upgrade
Hey i was just was wondering can you put 2 single din radios in the double din area of the radio. If so where can i get the dash instal kit from, also what do i need to keep my wheel contrils when i put in a aftermarket radio
Old Sep 27, 2007 | 08:46 AM
04 Intimidator's Avatar
Default RE: Radio upgrade
I've never heard of a kit to put 2 radios in the double din area. I'm also trying to understand this as well, why would you want to do this? I'm just not seeing what 2 head units would accomplish.
Scoshe makes a modual to get the steering wheel controls to work but I had/still am having a difficult time getting it hooked up. I worked on it for 3 hours one day and just haven't bothered since. I think it might be a wire I have hooked up wrong. drk blue and lite blue look very similiar in a dark area when you can barely see the wiring harness.
Old Sep 27, 2007 | 10:18 AM
MIKE07083's Avatar
hey,i friend of mine with an '02 m/c used two din sized units in his double din openning and it looks good. he used a pioneer head unit and the deq-7600 din sized eq. looks and sounds great. he had to use an aftermarket amp instead of using the factory amp tho. hope this helps
Old Sep 27, 2007 | 10:20 AM
vita's Avatar
alright, well:
Im guessing your going to have to forge something up yourself for the din kit. im guessing the two things are like a radio and then a dvd reciever?
the wheel controlls can be used if you get an adapter and plug it into the wiring harness. check out www.crutchfield.com they usually have a great selection on hand for things like that and their the most reasonably priced I could find. ive used them before, andI would do it again.
lucasmblanco
Jan 27, 2014 12:20 AM
guysnydr
Sep 18, 2013 07:43 PM
dustybird3
Apr 8, 2011 10:10 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
fat rat
Oct 5, 2004 06:51 PM
