Audio/Video Build: Problems with after market stereo
Old Jul 23, 2021 | 02:21 PM
MARCTARTAGLIA's Avatar
Default Problems with after market stereo
I put a pioneer deh-s4120bt in my 2002 Monte Carlo SS in December last yr. Hooked up a 3000 watt amp and subs. Everything worked great until this past week when my area got hit hard with rain. Had to drive thru a flash flood spot and now the stereo doesnt turn on at all. I checked the fuse in the stereo and in the fuse box under radio and accessories and no fuse has been blown in any of the circuits. What do I do to get it running again?
Old Jul 27, 2021 | 05:50 PM
Time to break out the multimeter.
Check to make sure its got constant and switched 12 volts at the back of the radio. Then check for ground continuity.
If its got both powers and ground at the radio, I'd unhook your amp trigger and RCAs and try to turn it on again. If that doesn't work, then I'd also disconnect all 4 speakers. If it still won't turn on, the radio is bad internally.
r00t
Apr 17, 2015 09:43 AM
cole4201
Jan 15, 2014 05:54 PM
Dazoli
Feb 6, 2013 03:44 PM
dz93
Sep 2, 2010 06:43 PM
chelseegtp97
Oct 31, 2008 09:45 AM
