Power mirrors not working?
Old Apr 1, 2011 | 02:12 PM
jwjones's Avatar
Default Power mirrors not working?
My 01' SS mirrors are not working properly. both sides will move in but not out, or up and down.
Old Apr 1, 2011 | 05:27 PM
is the fuse good? also i think there's a relay for it, may want to check that too
Old Apr 2, 2011 | 10:06 AM
jwjones's Avatar
Checked the fuse this morning, it was not blown
Old Apr 2, 2011 | 10:52 AM
Milhouse's Avatar
Of course not, if the fuse was blown then the mirrors wouldn't move at all. The problem is most likely in the switch, but possibly in the motor itself. I'm sure replacing the switch is alot cheaper than the motor (if you can even replace that by itself) so my suggestion would be to start there.
Old Aug 11, 2012 | 06:47 PM
Robert Ford's Avatar
Almost the same problem here. Replaced the switch and nothing changed. Both mirrors tilt up, but that's it.
Old Aug 11, 2012 | 07:41 PM
Might be a bad motor if it's not moving side to side.
Old Aug 12, 2012 | 02:26 AM
I had a van with power mirrors that would only go so far. Best I can figure is someone pushed the mirror in and skipped the gears so it would only move so far back up and then it would click. I had to push it back to center and "realign it" I'm not sure if this is your problem or if it will work on a monte but it may be worth a try.
aubiegrl93
May 16, 2014 09:51 AM
GMfever
Jun 22, 2013 03:33 PM
darren700
Jun 3, 2010 05:59 PM
GABRIEL84SS
Mar 26, 2010 11:26 PM
paintballerr78
Sep 6, 2009 06:36 PM
