pcm upgrade???
Old Mar 3, 2010 | 11:58 PM
chriscleveland86's Avatar
Default pcm upgrade???
so i found this webiste that can upgrade your pcm for like 190 bucks or so. would it be worth it?? does any have a 01-04 mc ss with upgraded pcm computer???
Old Mar 4, 2010 | 08:47 AM
Most of us who have mods have a tuned PCM. My was custom tuned by a friend with tuning software, specifically dialed in to my modifications.
If you want to get a tuned PCM, figure out what mods you want first, then do the PCM. And look at vendors such a ZZPerformance, Overkill, Intense
Old Mar 5, 2010 | 12:28 AM
Jomao_o's Avatar
Hey Mike, or any member that would know.
Will i have to upgrade PCM after installing a Wiz Air CAI? thanks. (sorry, i didn't mean to take a way from your thread, but since its a PCM questions i think its relevant)
Old Mar 5, 2010 | 08:25 AM
For just a CAI, you can disconnect the battery for an hour and let the car learn the new air flow. I would wait for more mods before you decide on a PCM.
However, if you aren't going to mod anymore, a nice PCM will always be nice.
Old Mar 5, 2010 | 10:41 AM
You really don't "have" to upgrade the pcm with any normal bolt ons. The computer measures the air entering the engine (the nice thing about having a MAF system), and the O2 sensor outputs to always keep the engine running correctly.
The thing is, even the factory pcm on a stock car isn't perfectly dialed in to the specific engine- so it has to make adjustments all the time based on weather and such. So even getting a tuned pcm on a stock setup has benefits (on top of all the other stuff it offers such as shift performance and such)- the more mods you do, the more the pcm is having the skew to make the engine run normally, the better it is to get a tuned pcm to dial it in.
The downside is a canned pcm off the shelf isn't going to get your car perfectly dialed in. They do definitely modify the known problem areas, but it will never be as 'dialed in' as a custom tune done with your specific vehicle (scan, flash, drive, scan, flash, drive, etc).
Old Mar 6, 2010 | 08:53 PM
Jomao_o's Avatar
Wow, thanks for the info guys.
Old Mar 6, 2010 | 08:58 PM
will the pcm learn it anyways if i didnt unplug my battery for an hour?
Old Mar 6, 2010 | 11:56 PM
Yes. Your computer is always relearning fuel trim changes from even such minor stuff as weather changes.
Old Mar 7, 2010 | 01:47 AM
MonteLSV6's Avatar
You should ask Mike from Milzy. He's really great to talk to, as I talked to him about the PCM and what it can do for my car (3.4L). He answered every question I had about the PCM tune. Starting at just $75 and an extra $10 for stage 1, stage 2, and +$50 for custom, you can't go wrong
lucasmblanco
Jan 27, 2014 12:20 AM
The_Maniac
Nov 10, 2010 09:42 AM
peoples 01 ss
Feb 27, 2010 12:31 AM
JHoersten2
Apr 4, 2005 02:38 AM
fat rat
Oct 5, 2004 06:51 PM
