pass. window help
Old Jan 2, 2010 | 09:30 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Default pass. window help
hey guys my passenger window when i roll it up stops and goes sometimes when i roll it up. sometimes it works, sometimes it doesnt. i'll be rolling it up and all the sudden it will stop, then it'll start again. what do i need to fix it and is it easy? im thinking regulator but not sure, maybe motor?
Old Jan 2, 2010 | 10:08 PM
mrl390's Avatar
I would check the switch first. Does the window work normally with the passenger side switch? If so, your window switch on the drivers side may be bad.
Old Jan 2, 2010 | 10:29 PM
shingding88's Avatar
if it isnt the switch the motor on your power window may be going bad. and from past experience, if it is bad, replace both. if one goes bad the other is soon to follow
Old Jan 2, 2010 | 11:50 PM
agreed with shingding, ive been looking into this whole gauge cluster going bad and sometimes it works and doesnt, well i know this has nothing to do with the window but im thinking that your motor is probably going bad and sometimes it has the power to let it work and sometimes it just doesnt have enough left in it, let us know how it goes
Old Jan 3, 2010 | 10:02 AM
mrl390's Avatar
Usually a when a power window motor goes out, it just stops working, it doesnt intermittently work then not work. Thats more the symptoms of a bad window switch. Like I said, roll the window up and down with the passenger side switch, if you dont have any problems with the window, then its not the motor, its the drivers side switch.
Old Jan 3, 2010 | 11:32 AM
tony1379's Avatar
I just cahnged the motor in my van was doing the same thing some times it worked. Changed it now works perfect.
Old Jan 3, 2010 | 08:31 PM
Photobucket
i gonna check it out tomorrow I'll let you all know how it goes thanks for the responses, might have more questions to come lol
stumped
Feb 20, 2015 07:45 AM
jufison
Sep 19, 2013 11:17 AM
qcakartracer
Nov 23, 2012 08:31 AM
Suppoko
Aug 26, 2009 06:48 PM
montecarloenthusiast
Jul 10, 2007 06:20 PM
