need to run a 12v line
Old Aug 31, 2012 | 01:29 PM
matt99199's Avatar
Default need to run a 12v line
i have a 2000 monte carlo SS and i need to run a 12v line from somewhere and i was wondering where is a good spot. my initial thought was to run it from the auxiliary power fuse but idk.
Old Aug 31, 2012 | 03:50 PM
zzapultimate's Avatar
What are you going to be powering with the 12V line?
Old Aug 31, 2012 | 11:41 PM
If it's something small like a radar detector or less I would do the ACC fuse... if it's an amp cable, run it straight to the battery.
Old Sep 1, 2012 | 04:29 AM
matt99199's Avatar
its a megaphone with a max draw of 4.4A peak.
Old Sep 1, 2012 | 07:31 AM
03SSLE's Avatar
Is this a hand held megaphone or a loudspeaker you're going to mount underhood? If it's hand held why not wire a plug to it and power it through the cig lighter/access power jack when needed? If it's an underhood loudspeaker I'd wire it to the aux lug by the battery through a fuse.
Old Sep 1, 2012 | 12:13 PM
Didnt CB radios have those to?
Id hook it right to the aux in the fuse box...
Whats the purpose of the megaphone?
Old Sep 1, 2012 | 01:14 PM
matt99199's Avatar
the megaphone was handheld but i modified it so now its underhood. the purpose is to **** with people btw. ill mount it to the aux lug.
Old Sep 1, 2012 | 01:37 PM
tps221's Avatar
i would say the power drop under the glove box i have that powering my 2 10's 800watt amp with a frame ground of course
oaky812
Aug 7, 2024 03:49 PM
Josh_NGR
Mar 21, 2012 08:56 PM
Barovelli
Jan 30, 2012 08:08 AM
TTT_Travis
14
Oct 7, 2009 10:37 PM
05_monte
Aug 23, 2009 07:25 PM
