Need a power source when car is off
Old Jun 19, 2013 | 07:48 PM
INTMD8R3's Avatar
Default Need a power source when car is off
I was wondering if anyone knows what fuse is constantly hot? Like power all the time even when the key isnt even in the ignition. I tried to use a test light to find one and had no luck.
Old Jun 19, 2013 | 07:59 PM
turbo monte's Avatar
idk why you need this but if i were you i would just run a wire off the battery and put a inline fuse on it....
Old Jun 19, 2013 | 08:09 PM
INTMD8R3's Avatar
Is there any other way?? I have all the amp power wires hooked up to the battery and tied up real nice,looking good. Didnt want to go that route.
Old Jun 19, 2013 | 09:40 PM
JC Colon's Avatar
If I am not mistaken, the power seats, dome lamps, brake lights and cigarette lighter are all hot with or without the key. But these may cause your head unit, if that is what you need it for, to have alternator noise and you have to tap the power before the fuse or it will blow from the extra current. For the last stereo I built, in a 98 Altima, I ran an 8 Gage wire from the battery to a 1 in 4 out splitter under the dash. Then ran 10 Gage to inline fuses to my 2 800w amps and head unit. And had an extra output just in case I decided to put a passive eq in the system. Ultimately, your be's bet is to run another wire from your battery or jumper/test terminals.
Like John said, whats the need? And if you're looking for an always on power source, battery..
Old Jun 20, 2013 | 06:20 AM
INTMD8R3's Avatar
Thank you guys... I guess ill go that route.....
RasCricket
Jan 23, 2014 03:22 PM
One Dark SS
Jan 13, 2012 04:02 PM
Tadcaster
Apr 11, 2011 05:48 PM
xjcurtisx
Jun 25, 2010 11:13 PM
04MonteLS
Jun 23, 2005 04:44 AM
