missing pieces
the top pic i believe is called a ignition bezel or something like that.
the bottom pic is where the fog light switch would go
junk yard would be your best bet to source these parts cheap.
Turbo Monte is CORRECT!!!
Your first pic is the Ignition cylinder trim bezel part number 10446064
Second pic is the Fog lamp switch location part number 10283833
Got these part numbers without a vin.... could always double check with a vin number.
Ignition lock Bezel (Off, ACC, On, Start) GM# 2852049
Ignition lock Bezel (Rubber Key Protector) GM# 10446064
Uploaded with ImageShack.us
Yeah i still havnt gotten around to getting them yet. Ill definitely buy if you get your hands on them!
Youre the man! Thanks everyone!
04MonteLS
Jul 23, 2009 12:23 AM
