6th Gen ('00-'05): Message center and radio compatibility
Old Nov 26, 2018 | 12:05 PM
1st-monte-ls's Avatar
Default Message center and radio compatibility
Ive been looking into installing one of those 7 inch touchscreen radio systems. But I don't want to lose the ability to reset the engine oil change message and those things. Do I need to stick with the single din to avoid this issue?
Thanks Y'all
Old Nov 26, 2018 | 06:34 PM
If you look in the owner's manual, I believe there is an alternate way to reset the Tire Life and Oil Life monitors. Key fob programming is done via the radio or with a GM Tech II. Some people relocated the factory radio elsewhere in the car to retain some of these functions.
Old Nov 27, 2018 | 10:09 AM
Thanks, I'll take a look as soon as I get my Monte back.
Old Mar 16, 2019 | 07:12 PM
phondo2's Avatar
We put a new touchscreen Pioneer in my 2001 Monte SS. New speakers too. We bought ours from Crutchfield.com. They sold us a kit to add on. All it does is warn if the seatbelt is not on, or if you leave your key in the ignition. I can say the chime is not very ear friendly. I can no longer program anything else. The oil light is from another sensor on mine. Hope this helps.
Old Apr 23, 2019 | 11:02 PM
Steelbizkit's Avatar
Alternate way to reset "Change engine oil"light is to floor the accelerator pedal to wot 3 times and hold on 3rd time. Some have to be done from throttle body as cable has stretched.
Kvanvoorst35
Oct 6, 2016 09:33 AM
S1knes
Dec 8, 2013 07:44 PM
speedySS18
14
Jan 7, 2013 02:20 PM
dealrocker
Jan 30, 2010 06:51 AM
willysmith
Apr 14, 2007 05:54 PM
