ls gauges to ss gauges
Old Aug 30, 2013 | 09:33 PM
MidNight Rider's Avatar
Default ls gauges to ss gauges
I searched the for this question but I guess I am not hitting the correct search words, I have a 01 LS and want to know is it possible to install the SS gauges.
Old Aug 30, 2013 | 10:15 PM
TMoney's Avatar
Its possible but the ls doesnt have the sender for the oil pressure i believe. The battery gauge will work though and everything else will work but not the oil pressure
Someone correct me if i am wrong
Old Aug 31, 2013 | 03:00 PM
I've done a lot of research on this, but don't have a car worth testing it on.
- With ONLY changing the cluster, all gauges, except the oil pressure will work.
What I found and no one has confirmed:
- You need to replace the oil pressure switch with an oil pressure sending unit.
- You need the connector for an oil pressure sending unit. This has 2 wires, the switch uses 1 wire. One wire is signal, the other wire (that you don't have) is nothing more then a ground.
- Wire in the new connector, install an oil pressure sending unit, done.
I've done a lot of reading and comparing of diagrams with the shop book and that's what it boils down to. It needs a ground to work.
If you make the swap, PLEASE post back. I've shared this info at least 3 times and I have yet to see anyone respond with additional information.
Old Sep 3, 2013 | 09:44 PM
I just have to bump this thread "because"....
@MidNight Rider - Just curious if you are going to pursue the cluster swap. I've been waiting to see if someone goes through the information i have found (so far, if they have no one reported back).
Old Sep 3, 2013 | 09:50 PM
TMoney's Avatar
Hey midnightrider, just thought if let you know if you do decide to do the swap, I have an ss cluster for sale
Old Sep 3, 2013 | 09:51 PM
I copied and pasted this info and emailed it to Matt. Pretty positive he will have the answer your looking for. Will let you know his reply when I get it. Stand By.....
Old Sep 4, 2013 | 05:32 AM
I know a lot of people claim it can't be done, but no one ever researched it or said why or that they tried it. Based on what I've found in the shop books, I think making the oil gauge work is as simple as I mentioned. I'd love to know if someone tried it out just to know if I'm right
Old Sep 4, 2013 | 06:54 AM
I am going to do this, I am on the hunt for cluster. to me this is a pretty much straight forward swap, I know that the oil pressure sending unit has to be changed out for one that reads pressure and not an idiot light. as soon as I find a cluster I will let you guys know.
Old Sep 4, 2013 | 10:44 AM
Here's an SS cluster for sale:
https://montecarloforum.com/forum/pr...44/#post568485
Also, you MUST change the connector when you install the oil sending unit. Your current oil switch has just one wire, the sending unit needs the 2nd wire (which is a simple ground). The other wire (that you already have) is the same regardless of which oil unit you have and goes to the same spot on the PCM.
Old Sep 4, 2013 | 07:22 PM
I have the SS cluster in my car... oil pressure always stays super low for some reason tho
