LED Strip repair
Old Dec 10, 2012 | 05:36 AM
Murray137's Avatar
Default LED Strip repair
As I was installing an old led the positive wire came loose and come out of its connector. How exactly do I fix this I tried just pushing it back in but it didn't work. Also hooked a wire from my sub to my toggle switch where my leds are wired to see if it would work and now sub don't work. Possible blow fuse on amp? Thanks in advance
Old Dec 10, 2012 | 03:31 PM
Justin Myers's Avatar
The wire came out of the light itself? if so you'll most likely have to solder it back on, and what do you mean you hooked a wire from the sub, the sub has to have a complete circuit to function
Old Dec 11, 2012 | 05:29 PM
Murray137's Avatar
fixed the amp, but still lost on the led, i keep trying to put the wire back in but still not getting any power at all
Old Dec 11, 2012 | 08:43 PM
Pics of what you're talking about?
If it's one of those little 25 cent strips just buy a new one?
Old Dec 12, 2012 | 12:15 AM
Pics would help for sure. Soldering the wire back on would be your best bet. It may not even be worth fixing because the price have come down on them so much you can probably replace it cheap.
Brotan3
Dec 27, 2013 11:51 AM
KingOf206
Dec 25, 2013 07:12 AM
Kayce Neuzil
Apr 12, 2012 09:29 PM
Cowboy6622
Nov 15, 2007 03:20 PM
1977Monte
Mar 16, 2007 09:44 PM
