interior lights dim when headlights are on
Old Jan 21, 2012 | 09:05 PM
robsly's Avatar
shortly after. I bet I fried it huh?
Old Jan 21, 2012 | 09:11 PM
Mike 00LS's Avatar
Well if you have a 2000, your BCM has nothing to do with your odometer - your mileage is stored in the cluster itself.
It's very possible that when the new battery got connected you created a surge if you weren't careful with the terminals.
Old Jan 21, 2012 | 09:12 PM
Boxman420's Avatar
it is possible. check the connections to the battery( sounds stupid but it could be a easy painless fix.) but it is possible you shorted something out
Old Jan 22, 2012 | 08:56 AM
Jester_20's Avatar
i'd almost bet it's a battery issue. If not a poor connection/bad battery it may be a weak alternator or bad connection between the alternator and the battery. I doubt it's BCM related, but i could be wrong.
Old Jan 22, 2012 | 09:08 AM
Heres my thought.....are u running a sound system? with amps?....I have a 1999..and im running 4000 watts......but what i did notice like urs.....the lights were diming in the interior...as well as the dash lights.....i dont know how many miles u have on it. But its still an "older' MODEL like mine.....i too tried replaceing the battery originally...
But soon after learned that wasnt the whole problem...turned out theres a diode inside the alternator that was causeing my issue..I replaced the alternator and now everything is bright ..like it was when it was new.....I would recomend haveing the chargeing system tested to be sure u have constant voltage....mine even started to pulse from 12 to 14 volts during the testing...didnt matter if it was at idle or under acceleration. which proved the alternator was faulty...replaced it and now i no longer have any issues.....hope this helps....
Old Jan 29, 2012 | 07:38 PM
yauny32's Avatar
im havin the same issue but even my headlights are dimmining ive checked all fuses theyre good and theres even some lights like my temperature lights that dont even light up nemore cant figure this one out
Old Jul 8, 2012 | 10:48 PM
rosymonte's Avatar
Default mine too
It started happening about a month ago. I also recently installed a new battery, but by recently I'm thinking maybe 6 months ago. My Monte is a 2001 or 02. I was thinking maybe it's an early sign the alternator is about to go. You never truly appreciate those interior dash lights until you no longer have them.
Old Jul 8, 2012 | 10:50 PM
rosymonte's Avatar
Default mine too
I think my temperature lights just died due to the car being 10 years old.
Old Jul 12, 2012 | 05:18 PM
Tom Bastys's Avatar
i have an 01 ss and was wondering if the little bubble on my dash is a photocell of some sort? i noticed when i put a clipboard on my dash one day they came on and my dash lights were very dim
Old Jul 12, 2012 | 08:47 PM
Regardless if its a new battery....If the diodes shot ...Then you need to replace the alternator as well!
TRobert
Aug 11, 2013 01:32 PM
Lorenzo
Apr 15, 2013 07:28 PM
Murray137
Jan 4, 2013 07:15 AM
silver1
20
Feb 20, 2010 06:15 PM
Yellow_Monte
Feb 14, 2008 09:28 AM
