interior lights dim when headlights are on
All my interior lightd dim after it gets dark enough for my headlights to come on automatically. Does anyone know if it could be a sensor? Any suggestions? Thanks.
Did you check the dimmer switch? Make sure the knob is turned almost all the way to the right, just before it clicks and turns on your dome and map lights.
I did check the dimmer switch. Someone told me it could be a module but I would have to go to the dealer because it also runs my odometer. It is all good with the daytime running lights. When it gets dark enough for the regular lights to come on, all interior lightd go dim. It's tough to watch the speed at night. I thought maybe there may be a sensor. Thanks.
that is really strange.. sounds like it might be a voltage issue... maybe...
Originally Posted by Boxman420
(Post 409081)
The BCM is the module I was thinking of. I was told a dealer has to put it in and reprogram it due to it also running the odometer. I was told that could run $150 and up. Thanks again.
Originally Posted by robsly
(Post 409090)
Was the car ever jump started? |
Mine is a 2000. So maybe that would be a help since it's older.
I did change batteries recently though.
did it happen suddenly after you changed batteries?
