7th Gen ('06-'07): interior fan
Old May 20, 2023 | 07:01 PM
95mercuryxr's Avatar
Default interior fan
have a question i replaced my resistor and fan for the hvac and i do not have the fan working. i am not sure if i am over looking some thing i checked all of the wires going to the ac module and power is going to it. there is no power going to the resister and the fan. this is the second one i have gotten and both are doing the same thing. is there another fuse or something the wires and plugs are still looking brand new no cuts or breaks any where. is there a fuse i am missing or do i have just bad luck with them. also could the bcm going bad again? it will be the fourth one that went bad if the bcm went bad. how often do these bcm go bad that takes out things? please don't say bcm am i just over looking something
Old May 21, 2023 | 08:50 PM
There are fuse panels. I believe of the 06-07 Monte, there is one on both sides of the dash that you can access when the doors are open and another panel in the engine compartment. Odds are there is fuse and/or relay in one of the panels on the dash. I would start there.
Old May 25, 2023 | 08:37 PM
monte07's Avatar
actually maniac there isn't any fuse pannels on the sides of the dash like the 6th gen has. Sadly i have looked as well. I hve code B0418-04 and B0223-4. I am wondering what those are my self isnt the last one for the reserculation aspect for the actuatoe where the fresh air actuator is and the B0418-04 that tempuature one for cold and heat actuator. I am trying to find out what they are. I had a code for my a/c module and those. I am stummped to try to figure out what exactly those are and fix them.
Old May 25, 2023 | 09:35 PM
Interesting, the car still has to have fuse panels (the one under the hood is not enough).
I just did a quick google search. Looks like GM moved them to the lower kick panel area. I forgot about that.
Old May 26, 2023 | 05:02 AM
monte07's Avatar
those are the only two unfortunately and very vage on qhat they are.
Old May 26, 2023 | 07:27 AM
What do you mean they're vague - isn't there a fuse layout diagram?
For the OP's situation, I'd probably switch my multimeter to continuity mode (beeps when the probes are electrically connected) and just run through checking every fuse from the top (there should be two tiny bits of the tops of the blades exposed so you don't have to physically remove them).
Old May 26, 2023 | 11:58 AM
monte07's Avatar
yeah did that ended up tracking it down to the actuators the one that brings in fresh air and the one that switches the heat.. it has been frustrating because it came up qith those body codes for the reserculation stuck open and the heat one stuck open the qires and plug are good got continuity out of them as well as power. Stinks i usually get those tick of death out of them. Just leaves me going wtf because it's just a pain to replace them. Also thank you bumpin
Old May 26, 2023 | 06:18 PM
monte07's Avatar
Do have a question though the plug for the actuator that brings in out side air and recerculate where do we get a new plug the wires are ok but the plug it self is questionable. Need help finding that part number. Autozone does not have a part number for it. Plus qhat is that plug called
Old May 31, 2023 | 01:19 PM
monte07's Avatar
I found a shop that has them they cheanged them out for me wish they could have given me the part number. But there were the wire harness further back leading to the resister that had a break in it as well. They and i dont know where the break came from. It's in a spot where there is nothing there qith slack for it to rub on or be pulled appart. Frustrating time's
Onion39
Sep 19, 2021 02:47 PM
claydoh
Jul 8, 2019 07:26 PM
Helmittt
Jul 15, 2017 09:55 AM
domawi84
Jan 15, 2014 06:40 PM
monte07
Aug 28, 2011 08:01 AM
