Installing subs amp and deck, all aftermarket
Old Dec 25, 2013 | 07:29 PM
Intimidator38's Avatar
Default Installing subs amp and deck, all aftermarket
Hello everybody, im new to this forum, i need some help/suggestions
Im going to be installing a double din touchscreen, subs and an amp
Into my 2004 monte carlo ss, what other cables etc. will i need? And how should i go about doing this? Thanks alot to anyone that can help out
Old Dec 25, 2013 | 08:08 PM
JC Colon's Avatar
First, to MCF!
OK, are you installing just one amp for the Subs and your line outs to the original wiring? What do you have already?
Old Dec 25, 2013 | 08:11 PM
The amo is 1000 watt amp and 2 10 inch kickers, i havnt bought a deck yet
Old Dec 25, 2013 | 08:55 PM
bowtiebandit23's Avatar
your going to need the wiring harness thats applicable to your year monte,(walmart) as well as a GMOS-(cant remember if its the 1 or 4) for the door ding and other features you will need that the other harness can not provide.(best buy/ebay/etc,) plus the wiring for sub and amp with inline fuse!
Old Dec 25, 2013 | 09:25 PM
JC Colon's Avatar
Is the amp a 2 channel Stereo or a mono amp. Or can it do both?
There is a connector that allows your security and dimmer to work. You connect it to your aftermarket head unit. And it allows you to plug your aftermarket head unit directly to your OEM plug. You can get it at most Auto parts or car stereo stores. You will Also need RCA cables to go from the head unit to the amp, speaker wire to go from the amp to your subs. Power wire, I recommend 4 gauge pwr and gnd and a 14 gauge remote wire, So your amp turns on when you turn your head unit on. I've used Monster Cable™ in the past. They come in a kit with everything you need. Some even have a .5, 1 or 1.5 Farid Cap to hook into the pwr line to your Amp to isolate it and provide quicker base/pwr response.
If you do get a kit with a cap I recommend a 1f cap for your 1000w amp. And make sure your pwr wire is long enough to go from your Battery to your amp location with a little play at Both ends.
These are the essential.
Hope this helps!
Intimidator38
Mar 11, 2014 02:19 PM
dbaldwin
20
Dec 14, 2013 12:02 AM
Topdawg
Feb 5, 2012 11:54 AM
rjohnson0264
Feb 17, 2009 09:54 PM
CHOWEE21
Jun 26, 2006 10:12 AM
