Installing an Amp... need some help
Hey guys, I was searching the web on how to install a new AMP on My 01 Monte Carlo SS, and this forum seemed like a good place to ask.
I've already replaced the four speakers with two Kenwood 6x9s and two Kenwood 6.5" speakers.
I am now replacing the amp and installing a sub.
In a month I'll be replacing the deck.
The car has a stock amp on the celling of the trunk, and I want to replace it with the Kenwood KAC-6402 Car Amp.
http://www.autoaccessorystore.com/ho...detail&id=1834
That's the amp.
Now, how would I go about installing it? Is there a wiring harness that would make it similar to installing a deck? Or do I cut the wires out of the plug leading into the current amp and hook them up one by one.
If I hook them up one by one is there a wiring diagram out there?
Lastly, Could I use the same wire that powers the current amp, or should I run a new power cord from the battery to the amp?
I have no idea the specs or how much power goes to the stock amp.
I also have one more question.
I know how to replace the speakers - I've already done that, but as for the sub, do I just hook it up to the amp or do I also run it's own power cord from the battery to the sub?
Any suggestions, tips, and/or hints would be greatly appreciated!
Thanks a ton!
-Sam
That's the amp.
Thanks a ton!
-Sam
I was thinking about that, but I'd just rather give it to all of the speakers because they are all upgraded.
Plus that seems more difficult. I'm hoping to just swap them out.
you'd have to run a new power and ground for that amp and a remote wire to tell it to turn on. youd also have to run new wires for each speaker. i did it on my car a while back. right now ive got 2 spare batterys, 3 amps (1 4 channel and 2 2 channels), 2 12" directed sx12s' and 2 directed sx15's. the remote wire would be connected to the back of your radio (if you have an after market radio) or to your fuse box on the left side of your dash if you still have your factory radio
6th Gen ('00-'05): HELP installing aftermarket subs,amp,deck 2004 monte carlo ss intimidator
Intimidator38
03-11-2014 02:19 PM
l0gitech87
08-04-2011 09:28 PM
nebstewart07
06-19-2009 08:38 AM
mickey
08-23-2006 05:31 PM
Puppet Master
08-15-2006 07:44 PM
