I need help with undercar lights!!!!
Old Mar 10, 2011 | 01:59 PM
monte003's Avatar
Default I need help with undercar lights!!!!
ok so i was wiring in my switch for my lights and i wired the ground to a bolt under my shifter and then wired my power to the cigarette lighter cause its always hot well when i flipped on my switch on the light did not come on and now my cigarette lighter wont worak and the cigarette lighter fuse in not blow so idk what the problem... so if anyone had a better place to wire my switch or how to fix my problem please let me know.
Old Mar 10, 2011 | 03:31 PM
If none of the fuses are blown, my guess is your power wiring is loose. Double check your wiring.
BTW - How did you connect it? Did you use a barrel connector or soldier the wires together?
Old Mar 10, 2011 | 07:55 PM
monte003's Avatar
i connected it with barrels.....and i am getting no power to it so is there a place i could have pulled it out?
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
red06SS
31
Mar 5, 2007 04:53 AM
litecandy
Jun 26, 2006 05:13 PM
litecandy
Jun 26, 2006 04:00 PM
