hvac problem
Old Jul 30, 2013 | 12:13 PM
drmrgal's Avatar
Default hvac problem
Hey folk's I went to turn on my ac about a week ago and my fan motor will not work! I can feel cold air coming through the vents when I'm moving down the road. So I know my system is still working. Could my fan switch have gone bad as I know the hvac controls tend to have problems in the 6th gen montes .that's what I'm leaning towards. I don't think the fan motor is bad because it didn't give any hints of any problems. Any advice? Thanks
Old Jul 30, 2013 | 12:37 PM
KCFITZ78's Avatar
If the blower motor is good and works if you apply aux power to it then my best guess would be the "blower motor resistor". This resistor is used to dial in you fan speeds. Did it just stop working or at some point in time did you not have all your fan speeds?
This resistor is known to go bad, but if you do replace it check the wiring as sometimes the wire breaks through the insulation and shorts out the resistor. If you just replace it and have an exposed wire the resistor will just short out again.
Also see this thread for removal:
https://montecarloforum.com/forum/si...esistor-43899/
Old Jul 31, 2013 | 05:48 AM
drmrgal's Avatar
Thanx for the a advice I'll check that resistor soon. My fan motor did just quit on me. One day working fine on all speeds the next day nothing.
Old Jul 31, 2013 | 05:53 AM
drmrgal's Avatar
Also thanx for the Write up that will be a big help.
Old Jul 31, 2013 | 08:15 AM
03SSLE's Avatar
Have you checked the blower motor fuse? When the switch is in the high position it bypasses the resistor so if you don't get power to the blower motor in that position the problem is something other then the resistor.
98Z34
Apr 2, 2014 07:36 PM
mickey
FWD Tech Guides '95-'07
41
May 15, 2011 10:30 PM
northleaf
Jan 14, 2010 01:50 PM
cqdqd2
Jul 23, 2008 08:18 PM
desighitter
May 30, 2006 11:12 AM
