how the hell do you take out the map light bulb??
Old Oct 6, 2009 | 06:47 PM
nemesis's Avatar
2009 Monte Of The Year
Default how the hell do you take out the map light bulb??
how do you take them out any tip or advice? i tried every methods i know of, but have hard time getting that sucker out. i tried using the fuse puller, but that didn't work cause there's no room to grab it. i thought about using needle nose plier but afraid i might break the bulb. anybody know an easier way to to take it out?
Old Oct 6, 2009 | 08:17 PM
The Popcorn King's Avatar
Didnt Mike have a write up about that?
https://montecarloforum.com/forum/sh...ad.php?t=15828
Old Oct 6, 2009 | 09:08 PM
i thought the map light and dome light were like two different lights??
Old Oct 6, 2009 | 09:19 PM
jimbo7's Avatar
it takes more force than you think! i had to use some smallish curved needle nose pliers to grab the bulb by it's base and kinda pry it out like a nail. it popped out fairly easy that way. pain in the a$$ though.
Old Oct 6, 2009 | 09:25 PM
in the mirror? use a flat head screw driver and pry it from the top and it will pop out, do it over something soft tho because it comes out fast sometimes, it does work tho
Old Oct 7, 2009 | 09:06 AM
Yay for my sticky! :P
IDK why everyone is using pliers and such, are my fingers that much smaller than yours that I can just reach in with my thumb / index pinch the bulb and pull it out?
Old Oct 8, 2009 | 04:18 PM
M.C.BOB's Avatar
I couldn't fit my fingers in there. I'm not sure what the tool is called, but I used neddle nose with the point basically chopped off, so it was flat. Got a grip on the bulb, pulled it out. It's a pain, scrated the chrome a little but, but no big deal.
Old Oct 10, 2009 | 01:12 AM
KINGSS's Avatar
i just recently took mine out.just use some needle nose and pull it out but make sure you hold the mirror as well.have fun!
Old Aug 17, 2021 | 04:36 PM
LaserBlueMonte's Avatar
Default Zip Ties!
Howdy! I was spending the better part of 2 hours trying to replace the map light bulbs on my '05 Monte Carlo! After some trial and error, I found that using zipties was a really easy way to remove them without using a dedicated tool or some sketchy pliers. I hope this technique helps someone else! (This is my first post on here, be easy on me!)
Push the ziptie back so that its hugging the bulb near the base
Tighten it with a finger as well as you can and then wiggle it back and forth, pulling away from the bulb base. It should eventually come out, granted you give it some elbow grease!
Success!
Replaced with some 194 LEDs. Very nice!
Old Aug 19, 2021 | 10:14 AM
Cool slik Idea
Success!
Slik idea thanks for sharing that , this is a really old thread back in 2010 you might want to show this and start a new thread.
KINGBASS
Aug 9, 2015 08:57 PM
Nas Escobar
Jun 23, 2014 12:33 AM
Sep 10, 2012 11:52 PM
Budsjlm
Oct 19, 2009 09:53 AM
RickCoMatic
May 27, 2009 03:48 PM
