HID Intensity Choice
#61
Take the light off and pull all the bulbs out, then spray in both the turn signal hole and the high beam hole, don't spray too hard, but enough to make all the junk blow out.
Worked great for me
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
If you can feel it on the outside with your fingernail, you have some sanding and buffing to do
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
#62
Check out the below `vid & link. I hope it helps with your prob - good luck from `Space
How to remove moisture/condensation/water from inside your headlights easy. You need to get the moisture out before you seal the leak! http://how-to-detail.com
For the step by step Repair tutorial and Videos go to my site at
Common Problems/Solutions | Auto Detailing, How to detail a car!
#64
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
![WTF](https://montecarloforum.com/forum/images/smilies/wtf.gif)
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
That's what's on the below link, but warning, I've never tried `it (LOL)
How to Remove Condensation From Headlights | eHow.com <~ Click
* I just parked my Monte facing the Sun & that took the moisture out of mine...
#66
You most certainly need a harness on 55W, and it's highly recommended that you use one on a 35W too just because the initial power consumption drawn at the start up of the HIDs is much more powerful than the stock wattage. Over a period of time this could damage all the wiring.
Do you mean putting a 55W in the highs and disabling the DRLs? That works either wattage.
#67
I'm eager to order my HID kit and I'm taking all of the info I can get about the safest set up for my car. You recommend a harness for my system. I understand the ballasts needing more power to start initially. I just wonder if you or anyone who has the set up with the harness could post a picture of it so I know roughly what it should look like. I would greatly appreciate it! Happy modding!
![Congrats](https://montecarloforum.com/forum/images/smilies/congrats.gif)
#69
Hey everyone! Just thought I'd let everyone know I ordered, received and installed a set of 35w 5000K bulbs from DDM in my Monte. They look phenomenal and I'll post pictures when I get the chance. The only confusion I have with them is that the female plug on the ballasts must've been wired in reverse, because when I plug them in the proper way for the clips to work, the bulbs won't work, but if I flip them around they light up perfectly. Anyone have this experience?
