HELP Loud chimes ~>Going Crazy - HELP : )
Why is the chime level so loud ? I have 2 options, normal and loud. I set it to normal but its unacceptably loud in my option. Lets just say if your standing 20 feet from the car with the doors shut you still can still hear the chimes clearly. I'm afraid to even try the loud option, who would use that. This can't be to way it is and if it is I want to know how to disable it all together. It chimes 5 times, like if I don't put my seatbelt on or when I turn on the car. Anyone have any advise, thx.
Last edited by Space; May 4, 2011 at 11:21 AM. Reason: Changed 2 get attention from Tech Member's : )
I'm not sure, but I thought the chimes were controlled by the radio & through the speakers... Did you check your owner's manual ? Hopefully one of our expert tech member's can advise when they read you thread problem... Check the below link I found on our forum.
Good Luck
https://montecarloforum.com/forum/in...g-chime-16605/
p.s. You have a Beautiful Monte Carlo S.S. 4-Sure...
You can consider getting ear-plugs
until we find a
solution to your `Problem
(I don't like chimes or buzzer's either) Especially on my Wake`Up Alarm CLock : )
Good Luck
until we find a solution to your `Problem
Thx kid, haven't checked the manual, I will do so tonight. This is something thats bothered me since I got the car 1 year ago, thought I could ignore it but I can't anymore. There's no way of disabling it with the radio controls that I see. The only options are "normal" and "loud".
I can't take that loud buzz'in anymore
STOP, don't pull the trigger
Wait for a Member to HELP
or
Call 4 HELP
Good Luck - Don't Stress `Out
Be Happy to have a AweSome-Buzz'in Monte Carlo S.S.
or
Call 4 HELP
I'm sorry that none of our expert tech member's have been able to help `YET ? We shall bump this thread to see `if one of them reads about your `BUZZ Chime Problem & can assist with an answer...Don't Give `Up & Don't Shoot
https://montecarloforum.com/forum/in...r-chime-25903/
^^^^^^click above link ^^^^^^
thats interesting, they dont beep except for start so honestly idk what your huge problem with it is, mine are pretty loud, cant be heard outside the car but likly the unit you have is just like that. i can't immagine a single thing that would cause the unit to be extra loud ive neveer experienced it but if it bothers you and you think its a wiring issue, reqire from scrach and if it persists i'd say it's the unit natural tones, or a defective unit perhaps.
No, factory radio. Its just not when you start the car, if your backing up with the door open as I do daily. I don't open the door all the way just enough to park tight to the line at work. Also, if I'm driving a short distance in town I typically don't put on my seatbelt which causes it to go off every couple minutes.
Anyways, not gonna take the wiring apart so I'll have to live it it. I just can't see how mine is the only one doing this. I've never heard a car chime sound so loud in my life.
DTG
Dec 30, 2011 10:41 AM
Slugger088
Mar 16, 2011 07:40 AM
03 Sleeper SS
Jan 31, 2008 05:52 AM
