Help!!!1 mesed up installing new radio
Old Oct 28, 2011 | 02:41 PM
jlange101's Avatar
Default Help!!!1 mesed up installing new radio
when i was installing my aftermarket radio i forgot to tape off the wires when i went to test it and now neither of my radios work in the car i tested the factory harness for power and it has power can anyone help also my car dosent chime anymore when my headlights are on and the car is off can anyone help please
Old Oct 28, 2011 | 02:54 PM
sounds like wires touched and you blew a fuse. the fuse should be on either side of the dash when you open the door. Just replace that and you should be fine.
i would assume you blew the fuse on the aftermarket headunit also if it has a fuse, i would replace both.
Old Oct 28, 2011 | 03:01 PM
Best to disconnect the negative battery cable when messing with electrical stuff!!!
Old Oct 28, 2011 | 06:09 PM
walkingonabullet's Avatar
this has been solved, very much a blown fuse. check the yellow line on the deck, thats a constant hot if it was connected when they touched, it'd likley blow, they sometimes mount them in line, or in the back of the deck.
the fuse for the radio i believe is...driver side fuse box. i hate fuse hunting in these cars, i suggest just takking a fuse tester and testing the whole box rather than reading the diagram...the diagrams always gets me lost but thats me XD
Old Oct 30, 2011 | 12:57 AM
jlange101's Avatar
i did blow a fuse but i replaced it and still nothing and the stock one still wont work either but theres power to the stock harness still
Old Oct 30, 2011 | 01:04 AM
jlange101's Avatar
the fuse i replaced was the radio one on the passenger side of the car, are there other fuses that it could also be???
Old Oct 30, 2011 | 11:13 AM
did you check for a fuse on the drivers side?
Old Oct 30, 2011 | 02:05 PM
jlange101's Avatar
ya i did but i couldnt find any fuse panels on that side
Old Nov 4, 2011 | 09:04 AM
superrod29's Avatar
hmm... i have a 2000 and there are two fuse panels on either side of the dash, hidden until you open the doors, not sure if they changed anything from 2000-2005?
JayBay
Aug 3, 2015 10:38 AM
LilSeanCB
Jul 6, 2011 09:48 PM
04Monte78
Feb 5, 2011 03:26 PM
montecarlo1995
Jun 12, 2005 11:30 PM
montecarlo1995
May 16, 2005 12:20 PM
